VirtES (Virtual Enterprise Simulator): A Proposed Methodology for Enterprise Simulation Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper a methodology to develop simulation models is presented. The methodology is based on a multi-level simulation model which allows flexibility and process analysis. The present work starts from applied researches in different SME enterprises. Enterprise management often needs easy and fast developed tools to increase production capacity and flexibility. In many cases performances increase is possible only adopting a BPR (business processes reengineering) approach. Nevertheless the resistance to a BPR approach is underlined in recent bibliography. The proposed approach consists of a three stages methodology, named VirtES (Virtual Enterprise Simulator). VirtES methodology was first applied to ceramic tiles enterprises. The results achieved encourage the adoption to other industrial field.
Mots clés
03380369.pdf (144.16 Ko) Télécharger le fichier
hal-01055832 , version 1 (13-08-2014)
Paternité
Giovanni Davoli, Sergio A. Gallo, Riccardo Melloni. VirtES (Virtual Enterprise Simulator): A Proposed Methodology for Enterprise Simulation Modeling. International Conference on Advances in Production and Management Systems (APMS), Sep 2009, Paris, France. pp.374-380, ⟨10.1007/978-3-642-16358-6_47⟩. ⟨hal-01055832⟩
340 Consultations
218 Téléchargements
