Efficient Mutual Authentication for Multi-domain RFID Systems Using Distributed Signatures
The use of RFID technology in complex and
distributed environments often leads to a multi-domain RFID system in
which security issues such as authentication of tags and readers,
granting access to data, and revocation of readers turn into an
administrative challenge. In this paper, we propose a new
public-key-based mutual authentication protocol that addresses the
reader revocation problem while maintaining efficiency and identity
privacy. In addition, our new protocol integrates fine-grained access
control and key establishment with mutual authentication. The core of
our solution is the use of the concepts of key-splitting and distributed
signatures to solve the validation and revocation problem. We show that
our protocols can be implemented on RFID tags using lightweight
implementations of elliptic curve cryptography.
