Website Credential Storage and Two-Factor Web Authentication with a Java SIM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper two mobile website authentication schemes are proposed. The first enables authentication credentials (username and password) to be stored and retrieved securely from a mobile handset, and requires no changes to existing websites. The second scheme, which may optionally be used with the first, utilises a one-time password and is intended for applications requiring an enhanced level of authentication, e.g. financial services. Both authentication schemes use a Java SIM and ubiquitous mobile phone; with its familiar and convenient form factor and high user acceptance. Both schemes also provide protection against online phishing attacks.
60330231.pdf (301.08 Ko) Télécharger le fichier
hal-01056084 , version 1 (14-08-2014)
Paternité
Jonathan Hart, Konstantinos Markantonakis, Keith Mayes. Website Credential Storage and Two-Factor Web Authentication with a Java SIM. 4th IFIP WG 11.2 International Workshop on Information Security Theory and Practices: Security and Privacy of Pervasive Systems and Smart Devices (WISTP), Apr 2010, Passau, Germany. pp.229-236, ⟨10.1007/978-3-642-12368-9_17⟩. ⟨hal-01056084⟩
62 Consultations
167 Téléchargements
