Enhance Multi-bit Spectral Analysis on Hiding in Temporal Dimension - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Random delays and dynamic frequency switching are widely adopted in smartcards and embedded systems as temporal hiding countermeasures to side channel attack.Temporal hiding is regarded as efficient to enhance the security of cryptographic devices. However, spectral analysis with Fast Fourier Transform is a powerful method to defeat temporal hiding countermeasures. Spectral analysis shares the same merit with integration different power attack. Multi-bit spectral analysis is enhanced with partitioning power analysis, which is much more effective than the correlation power analysis in the spectral domain. Multi-bit spectral analysis effectively defeats temporal hiding countermeasure with floating-mean dynamic frequency switching countermeasure. It is suggested cryptographic devices should employ other countermeasures together with hiding to ensure side channel security.
Cardis.pdf (7.16 Mo) Télécharger le fichier
hal-01056102 , version 1 (14-08-2014)
Paternité
Qiasi Luo. Enhance Multi-bit Spectral Analysis on Hiding in Temporal Dimension. 9th IFIP WG 8.8/11.2 International Conference on Smart Card Research and Advanced Applications (CARDIS), Apr 2010, Passau, Germany. pp.13-23, ⟨10.1007/978-3-642-12510-2_2⟩. ⟨hal-01056102⟩
81 Consultations
82 Téléchargements
