A Token Based Approach Detecting Downtime in Distributed Application Servers or Network Elements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper defines and outlines and proposes a heuristic method to detect unavailability on a practical service created on the Internet. It uses a token that is passed between all the nodes. The algorithm is under trial in a set of servers spanning over multiple administrative domains. This paper confirms that using a simple token passed through the contributing applications servers, is able to detect unavailability without intruding or changing the service that one wants to monitor.
019_Microsoft_Word_EUNICE_2010finalupdate_28Final_Version_29_v1.pdf (172.8 Ko) Télécharger le fichier
hal-01056495 , version 1 (20-08-2014)
Paternité
Sune Jakobsson. A Token Based Approach Detecting Downtime in Distributed Application Servers or Network Elements. 16th EUNICE/IFIP WG 6.6 Workshop on Networked Services and Applications - Engineering, Control and Management (EUNICE), Jun 2010, Trondheim, Norway. pp.209-216, ⟨10.1007/978-3-642-13971-0_20⟩. ⟨hal-01056495⟩
44 Consultations
62 Téléchargements
