Establishment and analysis of a reference transcriptome for Spodoptera frugiperda - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BMC Genomics Année : 2014
Background
Spodoptera frugiperda (Noctuidae) is a major agricultural pest throughout the American continent. The highly polyphagous larvae are frequently devastating crops of importance such as corn, sorghum, cotton and grass. In addition, the Sf9 cell line, widely used in biochemistry for in vitro protein production, is derived from S. frugiperda tissues. Many research groups are using S. frugiperda as a model organism to investigate questions such as plant adaptation, pest behavior or resistance to pesticides.
Results
In this study, we constructed a reference transcriptome assembly (Sf_TR2012b) of RNA sequences obtained from more than 35 S. frugiperda developmental time-points and tissue samples. We assessed the quality of this reference transcriptome by annotating a ubiquitous gene family - ribosomal proteins - as well as gene families that have a more constrained spatio-temporal expression and are involved in development, immunity and olfaction. We also provide a time-course of expression that we used to characterize the transcriptional regulation of the gene families studied.
Conclusion
We conclude that the Sf_TR2012b transcriptome is a valid reference transcriptome. While its reliability decreases for the detection and annotation of genes under strong transcriptional constraint we still recover a fair percentage of tissue-specific transcripts. That allowed us to explore the spatial and temporal expression of genes and to observe that some olfactory receptors are expressed in antennae and palps but also in other non related tissues such as fat bodies. Similarly, we observed an interesting interplay of gene families involved in immunity between fat bodies and antennae.
1471-2164-15-704.pdf (2.17 Mo) Télécharger le fichier
1471-2164-15-704-S1.pdf (1.16 Mo) Télécharger le fichier
1471-2164-15-704-S10.docx (70.61 Ko) Télécharger le fichier
1471-2164-15-704-S2.pdf (157.88 Ko) Télécharger le fichier
1471-2164-15-704-S3.pdf (40.57 Ko) Télécharger le fichier
1471-2164-15-704-S4.pdf (56.82 Ko) Télécharger le fichier
1471-2164-15-704-S5.pdf (171.42 Ko) Télécharger le fichier
1471-2164-15-704-S6.pdf (138.24 Ko) Télécharger le fichier
1471-2164-15-704-S7.pdf (774.5 Ko) Télécharger le fichier
1471-2164-15-704-S8.pdf (110.11 Ko) Télécharger le fichier
1471-2164-15-704.xml (92.23 Ko) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
hal-01058982 , version 1 (29-08-2014)
Fabrice Legeai, Sylvie Gimenez, Bernard Duvic, Jean-Michel Escoubas, Anne-Sophie Gosselin Grenet, et al.. Establishment and analysis of a reference transcriptome for Spodoptera frugiperda. BMC Genomics, 2014, 15 (1), pp.704. ⟨10.1186/1471-2164-15-704⟩. ⟨hal-01058982⟩
1026 Consultations
669 Téléchargements
