Narrative Entertainment System with Tabletop Interface
We propose the Narrative Entertainment System with
Tabletop Interface. This system is using a miniature-shaped interface
called Physical Character. By recognizing the operation of Physical
Character, virtual actor's behavior is under control, and that offers a
method to create a story while playing with miniatures in a familiar way
since our childhood. In the form of intuitive operation with this
interface, you are not only an observer, but also a creator.
