Merging Live and pre-Captured Data to support Full 3D Head Reconstruction for Telepresence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes a 3D head reconstruction method for low cost 3D telepresence systems that uses only a single consumer level hybrid sensor (color+depth) located in front of the users. Our method fuses the real-time, noisy and incomplete output of a hybrid sensor with a set of static, high-resolution textured models acquired in a calibration phase. A complete and fully textured 3D model of the users' head can thus be reconstructed in real-time, accurately preserving the facial expression of the user. The main features of our method are a mesh interpolation and a fusion of a static and a dynamic textures to combine respectively a better resolution and the dynamic features of the face.
short1026_EG2014_CR_opt.pdf (210.7 Ko) Télécharger le fichier
hal-01060128 , version 1 (02-09-2014)
Cédric Fleury, Tiberiu Popa, Tat Jen Cham, Henry Fuchs. Merging Live and pre-Captured Data to support Full 3D Head Reconstruction for Telepresence. EG'14, Apr 2014, Strasbourg, France. ⟨10.2312/egsh.20141002⟩. ⟨hal-01060128⟩
589 Consultations
276 Téléchargements
