Sparse Acoustic Source Localization with Blind Calibration for Unknown Medium Characteristics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
We consider the problem of audio source localization in a medium with unknown characteristics, particularly the speed of sound within the medium. We propose an algorithm to retrieve both the speed of sound and the localized signals under reasonable assumptions such as smoothness of medium structure. We present initial simulation results for stationary sinusoidal sources both for the case of uniform and non-uniform speed of sound through the medium to demonstrate the performance of the proposed algorithm.
itwist14_spdofsound.pdf (85.61 Ko) Télécharger le fichier
hal-01060320 , version 1 (03-09-2014)
  • HAL Id : hal-01060320 , version 1
Cagdas Bilen, Srđan Kitić, Nancy Bertin, Rémi Gribonval. Sparse Acoustic Source Localization with Blind Calibration for Unknown Medium Characteristics. iTwist - 2nd international - Traveling Workshop on Interactions between Sparse models and Technology, Aug 2014, Namur, Belgium. ⟨hal-01060320⟩
291 Consultations
130 Téléchargements
