Identification of dynamic nonlinear thermal transfers for precise correction of bias induced by temperature variations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Céline Casenave
Gérard Montseny
  • Fonction : Auteur
  • PersonId : 942369
Henri Camon
We present a least squares method for dynamic correction of biases induced by temperature variations when very high precision is required. This method is based on a simple dynamic model allowing to take into account the macroscopic effects of complex underlying thermal phenomena inside the device
Preprint_Casenave_et_al._-_2010_-_Identification_of_Dynamic_Nonlinear_Thermal_Transf.pdf (1.09 Mo) Télécharger le fichier
hal-01061525 , version 1 (07-09-2014)
  • HAL Id : hal-01061525 , version 1
Céline Casenave, Gérard Montseny, Henri Camon, François Blard. Identification of dynamic nonlinear thermal transfers for precise correction of bias induced by temperature variations. Symposium on Design, Test, Integration & Packaginf of MEMS/MOEMS (DTIP 2010), May 2010, Seville, Spain. pp.376-381. ⟨hal-01061525⟩
119 Consultations
106 Téléchargements
