A new experimental setup to study the structure of curiosity-driven exploration in humans - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pierre Rouanet
Jonathan Grizou
  • Fonction : Auteur
  • PersonId : 933478
Manuel Lopes
Jacqueline Gottlieb
Adrien Baranes
  • Fonction : Auteur
  • PersonId : 850157
Pierre-Yves Oudeyer
We are presenting an exploratory study with humans designed to analyze and measure properties of curiosity-driven exploration of a priori unknown sensorimotor spaces. More specifically, we are interested in the relation between exploration and learning progress.
brice-icdl.pdf (739.94 Ko) Télécharger le fichier
hal-01061682 , version 1 (08-09-2014)
  • HAL Id : hal-01061682 , version 1
Brice Miard, Pierre Rouanet, Jonathan Grizou, Manuel Lopes, Jacqueline Gottlieb, et al.. A new experimental setup to study the structure of curiosity-driven exploration in humans. ICDL-EPIROB 2014, Oct 2014, Genoa, Italy. ⟨hal-01061682⟩
253 Consultations
355 Téléchargements
