Phase resetting for a network of oscillators via phase response curve approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biological Cybernetics (Modeling) Année : 2015
The problem of phase regulation for a population of oscillating systems is considered. The proposed control strategy is based on a Phase Response Curve (PRC) model of an oscillator (the first order reduced model obtained for linearized system and inputs with infinitesimal amplitude). It is proven that the control provides phase resetting for the original nonlinear system. Next the problem of phase resetting for a network of oscillators is considered when applying a common control input. Performance of the obtained solutions is demonstrated via computer simulation for three different models of circadian/neural oscillators.
PRC_control_2.pdf (446.55 Ko) Télécharger le fichier
hal-01061988 , version 1 (08-09-2014)
Denis Efimov. Phase resetting for a network of oscillators via phase response curve approach. Biological Cybernetics (Modeling), 2015, 109 (1), pp.95-108. ⟨10.1007/s00422-014-0629-z⟩. ⟨hal-01061988⟩
148 Consultations
220 Téléchargements
