Averaging in~LTL
For the accurate analysis of computerized systems, powerful quantitative formalisms have been designed, together with efficient verification algorithms. However, verification has mostly remained boolean--either a property is true, or it is false. We believe that this is too crude in a context where quantitative information and constraints are crucial: correctness should be quantified! In a recent line of works, several authors have proposed quantitative semantics for temporal logics, using e.g. discounting modalities (which give less importance to distant events). In the present paper, we define and study a quantitative semantics of LTL with averaging modalities, either on the long run or within an until modality. This, in a way, relaxes the classical Boolean semantics of LTL, and provides a measure of certain properties of a model. We prove that computing and even approximating the value of a formula in this logic is undecidable.
Logique en informatique [cs.LO]
