Global tracker: an online evaluation framework to improve tracking quality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Evaluating the quality of tracking outputs is an important task in video analysis. This paper presents a new framework for estimating both detection and tracking quality during runtime. If anomalies are detected in the tracking output results, they are categorized as natural phenomena or real errors using contextual information. As this framework should be generic and work on any kind of system (single camera, camera network), a re-acquisition step using a constrained clustering algorithm is also performed in order to keep track of the object even if it leaves the scene and comes back or appears on another camera. The framework is evaluated on two datasets using different kinds of tracking algorithms.
Global_tracker_an_online_evaluation_framework_to_improve_tracking_quality.pdf (1.43 Mo) Télécharger le fichier
hal-01062766 , version 1 (10-09-2014)
  • HAL Id : hal-01062766 , version 1
Julien Badie, François Bremond. Global tracker: an online evaluation framework to improve tracking quality. AVSS - 11th IEEE International Conference on Advanced Video and Signal-Based Surveillance, Aug 2014, Seoul, South Korea. ⟨hal-01062766⟩
94 Consultations
205 Téléchargements
