An Iterative method for solving the inverse problem in Electrocardiography imaging: From body surface to heart potential. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Solving the inverse problem in electrocardiogra- phy imaging (ECGI) is a challenging problem. In this work, we present an ECGI solver based on the iterative Kozlov- Maz'ya-Fomin (KMF) method. Because of the lack of gold standards data for this problem, we propose to test this method on synthetical data generated based on the bidomain state-of- the-art model. We segmented a real geometry of a 43 years old women and produced a computational geometry on which we run the forward problem body surface potentials BSPs. We analyse the reconstructed solution using the Relative error in time and space, the correlation coefficient and phase mapping procedure.
cinc2014.pdf (3.39 Mo) Télécharger le fichier
hal-01065107 , version 1 (17-09-2014)
  • HAL Id : hal-01065107 , version 1
Nejib Zemzemi, Hamed Bourenane, Hubert Cochet. An Iterative method for solving the inverse problem in Electrocardiography imaging: From body surface to heart potential.. IEEE Computers in Cardiology, MIT, Sep 2014, Cambridge, United States. ⟨hal-01065107⟩
369 Consultations
212 Téléchargements
