Scale Normalized Radial Fourier Transform as a Robust Image Descriptor
We present a new visual descriptor that combines a multi-scale Laplacian Profile with a Radial Discrete Fourier Transform. This descriptor exists at every position and scale in an image and provides a local feature vector that is both discriminant and robust to changes in orientation and scale. It has a variable description length, and thus can be easily adapted for a variety of applications, ranging from simple detection tasks on low power computing platforms to complex tasks requiring highly discriminant detectors. To demonstrate the discriminant power of this descriptor we employ it in its most compact form to construct a cascade of linear classifiers for detecting people in images. We compare this detector to cascades classifiers constructed using Haar wavelets, Gaussian derivatives and variable size block HOG descriptors. Our experiments show that a cascade with this descriptor performs well against the other three detectors when tested using a common publicly available data set. We examine the stability of the descriptor to changes in image rotation and scaling for different description lengths.
icpr2014_final.pdf (352.14 Ko)
Télécharger le fichier
posterICPR2014_FINAL.pdf (522.6 Ko)
Format : Autre
