An Analysis on Selection for High-Resolution Approximations in Many-Objective Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Lecture Notes in Computer Science Année : 2014
This work studies the behavior of three elitist multi- and many-objective evolutionary algorithms generating a high-resolution approximation of the Pareto optimal set. Several search-assessment indicators are defined to trace the dynamics of survival selection and measure the ability to simultaneously keep optimal solutions and discover new ones under different population sizes, set as a fraction of the size of the Pareto optimal set.
selection-ppsn14.pdf (165.43 Ko) Télécharger le fichier
hal-01066206 , version 1 (24-09-2014)
Hernan Aguirre, Arnaud Liefooghe, Sébastien Verel, Kiyoshi Tanaka. An Analysis on Selection for High-Resolution Approximations in Many-Objective Optimization. Parallel Problem Solving from Nature - PPSN XIII, Sep 2014, Ljubljana, Slovenia. pp.487-497. ⟨hal-01066206⟩
348 Consultations
180 Téléchargements
