Parametric estimation of pairwise Gibbs point processes with infinite range interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bernoulli Année : 2017
This paper is concerned with statistical inference for infinite range interaction Gibbs point processes and in particular for the large class of Ruelle superstable and lower regular pairwise interaction models. We extend classical statistical methodologies such as the pseudolikelihood and the logistic regression methods, originally defined and studied for finite range models. Then we prove that the associated estimators are strongly consistent and satisfy a central limit theorem, provided the pairwise interaction function tends sufficiently fast to zero. To this end, we introduce a new central limit theorem for almost conditionally centered triangular arrays of random fields.
cltIR.pdf (687.44 Ko) Télécharger le fichier
hal-01092225 , version 1 (08-12-2014)
hal-01092225 , version 2 (17-07-2015)
hal-01092225 , version 3 (01-10-2015)
Jean-François Coeurjolly, Frédéric Lavancier. Parametric estimation of pairwise Gibbs point processes with infinite range interaction. Bernoulli, 2017, 23 (2), pp.1299-1334. ⟨10.3150/15-BEJ779⟩. ⟨hal-01092225v3⟩
330 Consultations
154 Téléchargements
