Non-scattering wavenumbers and far field invisibility for a finite set of incident/scattering directions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems Année : 2015
We investigate a time harmonic acoustic scattering problem by a penetrable inclusion with compact support embedded in the free space. We consider cases where an observer can produce inci-dent plane waves and measure the far field pattern of the resulting scattered field only in a finite set of directions. In this context, we say that a wavenumber is a non-scattering wavenumber if the associated relative scattering matrix has a non trivial kernel. Under certain assumptions on the physical coeffi-cients of the inclusion, we show that the non-scattering wavenumbers form a (possibly empty) discrete set. Then, in a second step, for a given real wavenumber and a given domain D, we present a construc-tive technique to prove that there exist inclusions supported in D for which the corresponding relative scattering matrix is null. These inclusions have the important property to be impossible to detect from far field measurements. The approach leads to a numerical algorithm which is described at the end of the paper and which allows to provide examples of (approximated) invisible inclusions.
BoCNRevised.pdf (934.54 Ko) Télécharger le fichier
FarField.pdf (7.28 Ko) Télécharger le fichier
Iterations.pdf (5.93 Ko) Télécharger le fichier
hal-01109534 , version 1 (26-01-2015)
  • HAL Id : hal-01109534 , version 1
Anne-Sophie Bonnet-Ben Dhia, Lucas Chesnel, Sergei Nazarov. Non-scattering wavenumbers and far field invisibility for a finite set of incident/scattering directions. Inverse Problems, 2015. ⟨hal-01109534⟩
310 Consultations
405 Téléchargements
