On the smoothed complexity of convex hulls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marc Glisse
Xavier Goaoc
We establish an upper bound on the smoothed complexity of convex hulls in $\mathbb{R}^d$ under uniform Euclidean ($\ell^2$) noise. Specifically, let $\{p_1^*, p_2^*, \ldots, p_n^*\}$ be an arbitrary set of $n$ points in the unit ball in $\mathbb{R}^d$ and let $p_i=p_i^*+x_i$, where $x_1, x_2, \ldots, x_n$ are chosen independently from the unit ball of radius $\delta$. We show that the expected complexity, measured as the number of faces of all dimensions, of the convex hull of $\{p_1,p_2, \ldots, p_n\}$ is $O\left(n^{2-\frac{4}{d+1}}\left(1+1/\delta\right)^{d-1}\right)$; the magnitude $\delta$ of the noise may vary with $n$. For $d=2$ this bound improves to $O\left(n^{\frac{2}{3}}(1+\delta^{-\frac{2}{3}}\right)$. We also analyze the expected complexity of the convex hull of $\ell^2$ and Gaussian perturbations of a nice sample of a sphere, giving a lower-bound for the smoothed complexity. We identify the different regimes in terms of the scale, as a function of $n$, and show that as the magnitude of the noise increases, that complexity varies monotonically for Gaussian noise but non-monotonically for $\ell^2$ noise.
socg-final.pdf (987.47 Ko) Télécharger le fichier
Format : Figure, Image
hal-01144473 , version 1 (21-04-2015)
hal-01144473 , version 2 (23-10-2016)
Olivier Devillers, Marc Glisse, Xavier Goaoc, Rémy Thomasse. On the smoothed complexity of convex hulls. Proceedings of the 31st International Symposium on Computational Geometry, Jun 2015, Eindhoven, Netherlands. pp.224-238, ⟨10.4230/LIPIcs.SOCG.2015.224⟩. ⟨hal-01144473v2⟩
590 Consultations
301 Téléchargements
