Free boundary problems for tumor growth: a viscosity solutions approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2016
The mathematical modeling of tumor growth leads to singular " stiff pressure law " limits for porous medium equations with a source term. Such asymptotic problems give rise to free boundaries , which, in the absence of active motion, are generalized Hele-Shaw flows. In this note we use viscosity solutions methods to study limits for porous medium-type equations with active motion. We prove the uniform convergence of the density under fairly general assumptions on the initial data, thus improving existing results. We also obtain some additional information/regularity about the propagating interfaces, which, in view of the discontinuities, can nucleate and, thus, change topological type. The main tool is the construction of local, smooth, radial solutions which serve as barriers for the existence and uniqueness results as well as to quantify the speed of propagation of the free boundary propagation.
pme_HAL.pdf (680.94 Ko) Télécharger le fichier
fig1.pdf (314.29 Ko) Télécharger le fichier
fig2.pdf (291.3 Ko) Télécharger le fichier
hal-01155696 , version 1 (27-05-2015)
Inwon C. Kim, Benoît Perthame, Panagiotis E. Souganidis. Free boundary problems for tumor growth: a viscosity solutions approach. Nonlinear Analysis: Theory, Methods and Applications, 2016, 138, pp.207-228. ⟨10.1016/j.na.2016.01.019⟩. ⟨hal-01155696⟩
311 Consultations
337 Téléchargements
