Autoregressive functions estimation in nonlinear bifurcating autoregressive models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistical Inference for Stochastic Processes Année : 2017
Bifurcating autoregressive processes, which can be seen as an adaptation of autoregressive processes for a binary tree structure, have been extensively studied during the last decade in a parametric context. In this work we do not specify any a priori form for the two autoregressive functions and we use nonparametric techniques. We investigate both nonasymptotic and asymptotic behaviour of the Nadaraya-Watson type estimators of the autoregressive functions. We build our estimators observing the process on a finite subtree denoted by $\mathbb{T}_n$, up to the depth $n$. Estimators achieve the classical rate $|\mathbb {T}_n|^{-\beta /(2\beta +1)}$ in quadratic loss over Hölder classes of smoothness. We prove almost sure convergence, asymptotic normality giving the bias expression when choosing the optimal bandwidth and a moderate deviations principle. Our proofs rely on specific techniques used to study bifurcating Markov chains. Finally, we address the question of asymmetry and develop an asymptotic test for the equality of the two autoregressive functions.
BOv2.pdf (637.04 Ko) Télécharger le fichier
hal-01159255 , version 1 (02-06-2015)
hal-01159255 , version 2 (11-02-2016)
Siméon Valère Bitseki Penda, Adélaïde Olivier. Autoregressive functions estimation in nonlinear bifurcating autoregressive models. Statistical Inference for Stochastic Processes, 2017, 20 (2), pp.179 - 210. ⟨10.1007/s11203-016-9140-6⟩. ⟨hal-01159255v2⟩
380 Consultations
195 Téléchargements
