A Rellich type theorem for the Helmholtz equation in a conical domain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mathématique Année : 2015
We prove that there cannot exist square-integrable nonzero solutions to the Helmholtz equation in an axisymmetric conical domain whose vertex angle is greater than π. This implies in particular the absence of eigenvalues embedded in the essential spectrum of a large class of partial differential operators which coincide with the Laplacian in the conical domain.
Rellich-HAL.pdf (127.47 Ko) Télécharger le fichier
hal-01160242 , version 1 (04-06-2015)
Anne-Sophie Bonnet-Ben Dhia, Sonia Fliss, Christophe Hazard, Antoine Tonnoir. A Rellich type theorem for the Helmholtz equation in a conical domain. Comptes Rendus. Mathématique, 2015, ⟨10.1016/j.crma.2015.10.015⟩. ⟨hal-01160242⟩
363 Consultations
557 Téléchargements
