From Geometric Semantics to Asynchronous Computability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show that the protocol complex formalization of fault-tolerant protocols can be directly derived from a suitable semantics of the underlying synchronization and communication primitives, based on a geometrization of the state space. By constructing a one-to-one relationship between simplices of the protocol complex and (di)homotopy classes of (di)paths in the latter semantics, we describe a connection between these two geometric approaches to distributed computing: protocol complexes and directed algebraic topology. This is exemplified on atomic snapshot, iterated snapshot and layered immediate snapshot protocols, where a well-known combinatorial structure, interval orders, plays a key role. We believe that this correspondence between models will extend to proving impossibility results for much more intricate fault-tolerant distributed architectures.
35.pdf (369.83 Ko) Télécharger le fichier
hal-01207146 , version 1 (30-09-2015)
Éric Goubault, Samuel Mimram, Christine Tasson. From Geometric Semantics to Asynchronous Computability. DISC 2015, Toshimitsu Masuzawa; Koichi Wada, Oct 2015, Tokyo, Japan. ⟨10.1007/978-3-662-48653-5_29⟩. ⟨hal-01207146⟩
171 Consultations
79 Téléchargements
