Tooling Support for Variability and Architectural Patterns in Systems Engineering
In systems engineering, the deployment of software components is error-prone since numerous safety and security rules have to be preserved. Furthermore, many deployments on different heterogeneous platforms are possible. In this paper we present a technological solution to assist industrial practitioners in producing a safe and secure solution out of numerous architectural variants. First, we introduce a pattern technology that provides correct-by-construction deployment models through the reuse of modeling artifacts organized in a catalog. Second, we develop a variability solution , connected to the pattern technology and based on an extension of the common variability language, for supporting the synthesis of model-based architectural variants. This paper describes a live demonstration of an industrial effort seeking to bridge the gap between variability modeling and model-based systems engineering practices. We illustrate the tooling support with an industrial case study (a secure radio platform).
Génie logiciel [cs.SE]
