Reduction to a single closed equation for 2 by 2 reaction-diffusion systems of Lotka-Volterra type - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Applied Mathematics Année : 2016
We consider general models of coupled reaction-diffusion systems for interacting variants of the same species. When the total population becomes large with intensive competition, we prove that the frequencies (i.e. proportions) of the variants can be approached by the solution of a simpler reaction-diffusion system, through a singular limit method and a relative compactness argument. As an example of application, we retrieve the classical bistable equation for Wolbachia's spread into an arthropod population from a system modeling interaction between infected and uninfected individuals.
Reduction_v10.pdf (1.04 Mo) Télécharger le fichier
hal-01264980 , version 1 (30-01-2016)
hal-01264980 , version 2 (02-02-2016)
Martin Strugarek, Nicolas Vauchelet. Reduction to a single closed equation for 2 by 2 reaction-diffusion systems of Lotka-Volterra type. SIAM Journal on Applied Mathematics, 2016, 76 (5), pp.2060-2080. ⟨hal-01264980v2⟩
659 Consultations
235 Téléchargements
