Horizontal holonomy and foliated manifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales de l'Institut Fourier Année : 2019
Yacine Chitour
Erlend Grong
  • Fonction : Auteur
  • PersonId : 976077
Frédéric Jean
Petri Kokkonen
  • Fonction : Auteur
We introduce horizontal holonomy groups, which are groups defined using parallel transport only along curves tangent to a given subbundle $D$ of the tangent bundle. We provide explicit means of computing these holonomy groups by deriving analogues of Ambrose-Singer's and Ozeki's theorems. We then give necessary and sufficient conditions in terms of the horizontal holonomy groups for existence of solutions of two problems on foliated manifolds: determining when a foliation can be either (a) totally geodesic or (b) endowed with a principal bundle structure. The subbundle $D$ plays the role of an orthogonal complement to the leaves of the foliation in case (a) and of a principal connection in case (b).
Holonomy_Done.pdf (508.27 Ko) Télécharger le fichier
hal-01268119 , version 1 (08-03-2017)
Yacine Chitour, Erlend Grong, Frédéric Jean, Petri Kokkonen. Horizontal holonomy and foliated manifolds. Annales de l'Institut Fourier, 2019, 69 (3), pp.1047-1086. ⟨10.5802/aif.3265⟩. ⟨hal-01268119⟩
224 Consultations
401 Téléchargements
