Traveling Pulses for a Two-Species Chemotaxis Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Computational Biology Année : 2016
Mathematical models have been widely used to describe the collective movement of bacteria by chemotaxis. In particular, bacterial concentration waves traveling in a narrow channel have been experimentally observed and can be precisely described thanks to a mathematical model at the macroscopic scale. Such model was derived in [1] using a kinetic model based on an accurate description of the mesoscopic run-and-tumble process. We extend this approach to study the behavior of the interaction between two populations of E. Coli. Separately, each population travels with its own speed in the channel. When put together, a synchronization of the speed of the traveling pulses can be observed. We show that this synchronization depends on the fraction of the fast population. Our approach is based on mathematical analysis of a macroscopic model of partial differential equations. Numerical simulations in comparison with experimental observations show qualitative agreement.
plos_finalAvecFigures.pdf (1.61 Mo) Télécharger le fichier
hal-01302632 , version 1 (14-04-2016)
Casimir Emako, Charlène Gayrard, Axel Buguin, Luís Neves de Almeida, Nicolas Vauchelet. Traveling Pulses for a Two-Species Chemotaxis Model. PLoS Computational Biology, 2016, 12 (4), pp.e1004843. ⟨10.1371/journal.pcbi.1004843⟩. ⟨hal-01302632⟩
784 Consultations
154 Téléchargements
