Factorisation of RSA-220 with CADO-NFS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
We give details of the factorization of RSA-220 with CADO-NFS. This is a new record computation with this open-source software. We report on the factorization of RSA-220 (220 decimal digits), which is the 3rd largest integer factorization with the General Number Field Sieve (GNFS), after the factorization of RSA-768 (232 digits) in December 2009 [3], and that of 3 697 + 1 (221 digits) in February 2015 by NFS@home.
rsa220 (1).pdf (162.1 Ko) Télécharger le fichier
hal-01315738 , version 1 (17-05-2016)
  • HAL Id : hal-01315738 , version 1
Shi Bai, Pierrick Gaudry, Alexander Kruppa, Emmanuel Thomé, Paul Zimmermann. Factorisation of RSA-220 with CADO-NFS. 2016. ⟨hal-01315738⟩
1535 Consultations
1736 Téléchargements
