Quantifying the Survival Uncertainty of Wolbachia-infected Mosquitoes in a Spatial Model * - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Artificial releases of Wolbachia-infected Aedes mosquitoes have been under study in the past years for fighting vector-borne diseases such as dengue, chikungunya and zika. Several strains of this bac- terium cause cytoplasmic incompatibility (CI) and can also affect their host’s fecundity or lifespan, while highly reducing vector competence for the main arboviruses. We consider and answer the following questions: 1) what should be the initial condition (i.e. size of the initial mosquito population) to have invasion with one mosquito release source? We note that it is hard to have an invasion in such case. 2) How many release points does one need to have sufficiently high probability of invasion? 3) What happens if one accounts for uncertainty in the release protocol (e.g. unequal spacing among release points)? We build a framework based on existing reaction-diffusion models for the uncertainty quantification in this context, obtain both theoretical and numerical lower bounds for the probability of release success and give new quantitative results on the one dimensional case.
UQ_20170724.pdf (1.5 Mo) Télécharger le fichier
hal-01355118 , version 1 (24-08-2016)
hal-01355118 , version 2 (24-07-2017)
Martin Strugarek, Nicolas Vauchelet, Jorge Zubelli. Quantifying the Survival Uncertainty of Wolbachia-infected Mosquitoes in a Spatial Model *. 2016. ⟨hal-01355118v2⟩
506 Consultations
233 Téléchargements
