Active Decentralized Scale Estimation for Bearing-Based Localization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— In this paper, we propose a novel decentralized active perception strategy that maximizes the convergence rate in estimating the (unmeasurable) formation scale in the context of bearing-based formation localization for robots evolving in R 3 × S 1. The proposed algorithm does not assume presence of a global reference frame and only requires bearing-rigidity of the formation (for the localization problem to admit a unique solution), and presence of (at least) one pair of robots in mutual visibility. Two different scenarios are considered in which the active scale estimation problem is treated either as a primary task or as a secondary objective with respect to the constraint of attaining a desired bearing formation. The theoretical results are validated by realistic simulations.
IROS16_0412_FI.pdf (2.2 Mo) Télécharger le fichier
hal-01355789 , version 1 (24-08-2016)
  • HAL Id : hal-01355789 , version 1
Riccardo Spica, Paolo Robuffo Giordano. Active Decentralized Scale Estimation for Bearing-Based Localization. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'16, Oct 2016, Daejeon, South Korea. ⟨hal-01355789⟩
261 Consultations
412 Téléchargements
