Cyclic asymptotic behaviour of a population reproducing by fission into two equal parts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Kinetic and Related Models Année : 2019
We study the asymptotic behaviour of the following linear growth-fragmentation equation $$\dfrac{\partial}{\partial t} u(t,x) + \dfrac{\partial}{\partial x} \big(x u(t,x)\big) + B(x) u(t,x) =4 B(2x)u(t,2x),$$ and prove that under fairly general assumptions on the division rate $B(x),$ its solution converges towards an oscillatory function, explicitely given by the projection of the initial state on the space generated by the countable set of the dominant eigenvectors of the operator. Despite the lack of hypo-coercivity of the operator, the proof relies on a general relative entropy argument in a convenient weighted $L^2$ space, where well-posedness is obtained via semigroup analysis. We also propose a non-dissipative numerical scheme, able to capture the oscillations.
BernardDoumicGabriel_final_hal.pdf (706.61 Ko) Télécharger le fichier
hal-01363549 , version 1 (09-09-2016)
hal-01363549 , version 2 (31-01-2017)
hal-01363549 , version 3 (01-11-2017)
hal-01363549 , version 4 (16-01-2018)
hal-01363549 , version 5 (17-11-2018)
Etienne Bernard, Marie Doumic, Pierre Gabriel. Cyclic asymptotic behaviour of a population reproducing by fission into two equal parts. Kinetic and Related Models , 2019, 12 (3), pp.551-571. ⟨10.3934/krm.2019022⟩. ⟨hal-01363549v5⟩
Relations
1036 Consultations
442 Téléchargements
