Monotone Simultaneous Paths Embeddings in $\mathbb{R}^d$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study the following problem: Given $k$ paths that share the same vertex set, is there a simultaneous geometric embedding of these paths such that each individual drawing is monotone in some direction? We prove that for any dimension $d\geq 2$, there is a set of $d + 1$ paths that does not admit a monotone simultaneous geometric embedding.
simultaneous-paths-embedding.pdf (294.34 Ko) Télécharger le fichier
Format : Figure, Image
hal-01366148 , version 1 (14-09-2016)
David Bremner, Olivier Devillers, Marc Glisse, Sylvain Lazard, Giuseppe Liotta, et al.. Monotone Simultaneous Paths Embeddings in $\mathbb{R}^d$. 24th International Symposium on Graph Drawing & Network Visualization, Sep 2016, Athens, Greece. ⟨10.1007/978-3-319-50106-2_42⟩. ⟨hal-01366148⟩
278 Consultations
398 Téléchargements
