A GPU-accelerated nodal discontinuous Galerkin method with high-order absorbing boundary conditions and corner/edge compatibility - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Engineering Année : 2017
Discontinuous Galerkin finite element schemes exhibit attractive features for accurate large-scale wave-propagation simulations on modern parallel architectures. For many applications, these schemes must be coupled with non-reflective boundary treatments to limit the size of the computational domain without losing accuracy or computational efficiency, which remains a challenging task. In this paper, we present a combination of a nodal discontinuous Galerkin method with high-order absorbing boundary conditions (HABCs) for cuboidal computational domains. Compatibility conditions are derived for HABCs intersecting at the edges and the corners of a cuboidal domain. We propose a GPU implementation of the computational procedure, which results in a multidimensional solver with equations to be solved on 0D, 1D, 2D and 3D spatial regions. Numerical results demonstrate both the accuracy and the computational efficiency of our approach.
hal-01383074 , version 1 (18-10-2016)
Axel Modave, Andreas Atle, Jesse Chan, Tim Warburton. A GPU-accelerated nodal discontinuous Galerkin method with high-order absorbing boundary conditions and corner/edge compatibility. International Journal for Numerical Methods in Engineering, 2017, 112 (11), pp.1659-1686. ⟨10.1002/nme.5576⟩. ⟨hal-01383074⟩
136 Consultations
0 Téléchargements
