Recognizing Shrinkable Complexes Is NP-Complete - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Geometry Année : 2016
We say that a simplicial complex is shrinkable if there exists a sequence of admissible edge contractions that reduces the complex to a single vertex. We prove that it is NP-complete to decide whether a (two-dimensional) simplicial complex is shrinkable. Along the way, we describe examples of contractible complexes that are not shrinkable.
jocg.pdf (4.29 Mo) Télécharger le fichier
supplementary-material.pdf (9.83 Mo) Télécharger le fichier
vignette.pdf (1.05 Mo) Télécharger le fichier
Format : Figure, Image
hal-01384396 , version 1 (19-10-2016)
hal-01384396 , version 2 (05-03-2018)
Dominique Attali, Olivier Devillers, Marc Glisse, Sylvain Lazard. Recognizing Shrinkable Complexes Is NP-Complete. Journal of Computational Geometry, 2016, 7 (1), pp.430--443. ⟨10.20382/jocg.v7i1a18⟩. ⟨hal-01384396v2⟩
918 Consultations
260 Téléchargements
