Path dependent equations driven by Hölder processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastic Analysis and Applications Année : 2019
This paper investigates existence results for path-dependent differential equations driven by a Hölder function where the integrals are understood in the Young sense. The two main results are proved via an application of Schauder theorem and the vector field is allowed to be unbounded. The Hölder function is typically the trajectory of a stochastic process.
Young_case_26oct2016Submitted.pdf (217.93 Ko) Télécharger le fichier
hal-01388433 , version 1 (27-10-2016)
Rafael Andretto Castrequini, Francesco Russo. Path dependent equations driven by Hölder processes. Stochastic Analysis and Applications, 2019, 37 (3), pp.480-498. ⟨10.1080/07362994.2019.1585263⟩. ⟨hal-01388433⟩
109 Consultations
73 Téléchargements
