Stability of a Delay System Coupled to a Differential-Difference System Describing the Coexistence of Ordinary and Mutated Hematopoietic Stem Cells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new mathematical model that represents the coexistence between normal and leukemic populations of cells is proposed and analyzed. It is composed by a nonlinear time-delay system describing the dynamics of ordinary stem cells, coupled to a differential-difference system governing the dynamics of mutated cells. A Lyapunov-like technique is devel- oped in order to investigate the stability properties of a steady state where healthy cells survive while leukemic ones are eradicated. Exponential stability of solutions is established, estimate of their decay rate is given and a subset of the basin of attraction of the desired steady state is provided.
Automatique
HALCDC.pdf (1 Mo) Télécharger le fichier
hal-01389870 , version 1 (30-10-2016)
hal-01389870 , version 2 (09-01-2017)
hal-01389870 , version 3 (08-02-2017)
Walid Djema, Frédéric Mazenc, Catherine Bonnet, Jean Clairambault, P Hirsch, et al.. Stability of a Delay System Coupled to a Differential-Difference System Describing the Coexistence of Ordinary and Mutated Hematopoietic Stem Cells. 55th IEEE Conference on Decision and Control (CDC 2016), Dec 2016, Las Vegas, United States. ⟨10.1109/cdc.2016.7798328⟩. ⟨hal-01389870v3⟩
497 Consultations
450 Téléchargements
