Asymptotic analysis and optimal control of an integro-differential system modelling healthy and cancer cells exposed to chemotherapy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal de Mathématiques Pures et Appliquées Année : 2018
We consider a system of two coupled integro-differential equations modelling populations of healthy and cancer cells under therapy. Both populations are structured by a phenotypic variable, representing their level of resistance to the treatment. We analyse the asymptotic behaviour of the model under constant infusion of drugs. By designing an appropriate Lyapunov function, we prove that both densities converge to Dirac masses. We then define an optimal control problem, by considering all possible infusion protocols and minimising the number of cancer cells over a prescribed time frame. We provide a quasi-optimal strategy and prove that it solves this problem for large final times. For this modelling framework, we illustrate our results with numerical simulations, and compare our optimal strategy with periodic treatment schedules.
ArticleControlCancer_v1_HAL.pdf (814.4 Ko) Télécharger le fichier
hal-01416594 , version 1 (14-12-2016)
Camille Pouchol, Jean Clairambault, Alexander Lorz, Emmanuel Trélat. Asymptotic analysis and optimal control of an integro-differential system modelling healthy and cancer cells exposed to chemotherapy. Journal de Mathématiques Pures et Appliquées, 2018, 116 (9), pp.268-308. ⟨10.1016/j.matpur.2017.10.007⟩. ⟨hal-01416594⟩
1082 Consultations
374 Téléchargements
