Approximation of CVaR minimization for hedging under exponential-Lévy models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2017
In this paper, we study the hedging problem based on the CVaR in incomplete markets. As the superhedging is quite expensive in terms of initial capital, we construct a self-financing strategy that minimizes the CVaR of hedging risk under a budget constraint on the initial capital. In incomplete markets, no explicit solution can be provided. To approximate the problem, we apply the Neyman-Pearson lemma approach with a specific equivalent martingale measure. Afterwards, we explicit the solution for call options hedging under the exponential-Lévy class of price models. This approach leads to an efficient and easy to implement method using the fast Fourier transform. We illustrate numerical results for the Merton model.
cvar-hedging-exp-levy.pdf (544.1 Ko) Télécharger le fichier
hal-01461215 , version 1 (07-02-2017)
Madalina Deaconu, Antoine Lejay, Khaled Salhi. Approximation of CVaR minimization for hedging under exponential-Lévy models. Journal of Computational and Applied Mathematics, 2017, 326, pp.171-182. ⟨10.1016/j.cam.2017.05.005⟩. ⟨hal-01461215⟩
350 Consultations
351 Téléchargements
