Global stability with selection in integro-differential Lotka-Volterra systems modelling trait-structured populations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Biological Dynamics Année : 2018
We analyse the asymptotic behaviour of integro-differential equations modelling $N$ populations in interaction, all structured by different traits. Interactions are modelled by non-local terms involving linear combinations of the total number of individuals in each population. These models have already been shown to be suitable for the modelling of drug resistance in cancer, and they generalise the usual Lotka-Volterra ordinary differential equations. Our aim is to give conditions under which there is persistence of all species. Through the analysis of a Lyapunov function, our first main result gives a simple and general condition on the matrix of interactions, together with a convergence rate. The second main result establishes another type of condition in the specific case of mutualistic interactions. When either of these conditions is met, we describe which traits are asymptotically selected.
ArticleLV_HAL_v4.pdf (283.8 Ko) Télécharger le fichier
hal-01470722 , version 1 (17-02-2017)
hal-01470722 , version 2 (22-03-2017)
hal-01470722 , version 3 (23-03-2017)
hal-01470722 , version 4 (14-04-2017)
Camille Pouchol, Emmanuel Trélat. Global stability with selection in integro-differential Lotka-Volterra systems modelling trait-structured populations. Journal of Biological Dynamics, 2018, 12 (1), pp.872--893. ⟨hal-01470722v4⟩
840 Consultations
329 Téléchargements
