Expected Length of the Voronoi Path in a High Dimensional Poisson-Delaunay Triangulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Computational Geometry Année : 2018
Let X be a d dimensional Poisson point process. We prove that the expected length of the Voronoi path between two points at distance 1 in the Delaunay triangulation associated with X is sqrt(2d/π) + O(d^(−1/2) when d → ∞. In any dimension, we also provide a precise interval containing the actual value; in 3D the expected length is between 1.4977 and 1.50007.
paper.pdf (789.02 Ko) Télécharger le fichier
maple-computations.zip (41.32 Ko) Télécharger le fichier
Format : Figure, Image
hal-01477030 , version 1 (26-02-2017)
Pedro Machado Manhães de Castro, Olivier Devillers. Expected Length of the Voronoi Path in a High Dimensional Poisson-Delaunay Triangulation. Discrete and Computational Geometry, 2018, 60 (1), pp.200--219. ⟨10.1007/s00454-017-9866-y⟩. ⟨hal-01477030⟩
304 Consultations
213 Téléchargements
