Interval observer for uncertain time-varying SIR-SI epidemiological model of vector-borne disease - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The issue of state estimation is considered for an SIR-SI epidemiological model describing a vector-borne disease such as dengue fever, subject to seasonal variations. Assuming continuous measurement of the incidence rate (that is the number of new infectives in the host population per unit time), a class of interval observers with estimate-dependent gain is constructed, and asymptotic error bounds are provided. The synthesis method is based on the search for a common linear Lyapunov function for monotone systems that represent the evolution of the estimation errors.
ECC18_S_FINAL.pdf (495.94 Ko) Télécharger le fichier
hal-01493078 , version 1 (20-03-2017)
hal-01493078 , version 2 (10-11-2017)
hal-01493078 , version 3 (07-03-2018)
Maria Soledad Aronna, Pierre-Alexandre Bliman. Interval observer for uncertain time-varying SIR-SI epidemiological model of vector-borne disease. ECC 2018 - European Control Conference, Jun 2018, Limassol, Cyprus. pp.1-6. ⟨hal-01493078v3⟩
630 Consultations
178 Téléchargements
