Higher order topological derivatives for three-dimensional anisotropic elasticity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2017
This article concerns an extension of the topological derivative concept for 3D elasticity problems involving elastic inhomogeneities, whereby an objective function J is expanded in powers of the characteristic size a of a single small inhomogeneity. The O(a 6) approximation of J is derived and justified for an inhomogeneity of given location, shape and elastic properties embedded in a 3D solid of arbitrary shape and elastic properties; the background and the inhomogeneity materials may both be anisotropic. The generalization to multiple small inhomogeneities is concisely described. Computational issues, and examples of objective functions commonly used in solid mechanics, are discussed.
m2an16.pdf (457.51 Ko) Télécharger le fichier
hal-01499498 , version 1 (31-03-2017)
Marc Bonnet, Rémi Cornaggia. Higher order topological derivatives for three-dimensional anisotropic elasticity. ESAIM: Mathematical Modelling and Numerical Analysis, 2017, 51, pp.2069-2092. ⟨10.1051/m2an/2017015⟩. ⟨hal-01499498⟩
213 Consultations
208 Téléchargements
