Super-linear propagation for a general, local cane toads model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Interfaces and Free Boundaries : Mathematical Analysis, Computation and Applications Année : 2018
We investigate a general, local version of the cane toads equation, which models the spread of a population structured by unbounded motility. We use the thin-front limit approach of Evans and Souganidis in [Indiana Univ. Math. J., 1989] to obtain a characterization of the propagation in terms of both the linearized equation and a geometric front equation. In particular, we reduce the task of understanding the precise location of the front for a large class of equations to analyzing a much smaller class of Hamilton-Jacobi equations. We are then able to give an explicit formula for the front location in physical space. One advantage of our approach is that we do not use the explicit trajectories along which the population spreads, which was a basis of previous work. Our result allows for large oscillations in the motility.
general_toads.pdf (293.23 Ko) Télécharger le fichier
hal-01520145 , version 1 (09-05-2017)
hal-01520145 , version 2 (17-05-2018)
Christopher Henderson, Benoît Perthame, Panagiotis E Souganidis. Super-linear propagation for a general, local cane toads model. Interfaces and Free Boundaries : Mathematical Analysis, Computation and Applications, 2018, 20 (4), pp.483-509. ⟨10.4171/IFB/409⟩. ⟨hal-01520145v2⟩
668 Consultations
252 Téléchargements
