Distributed synaptic weights in a LIF neural network and learning rules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physica D: Nonlinear Phenomena Année : 2017
Leaky integrate-and-fire (LIF) models are mean-field limits, with a large number of neurons, used to describe neural networks. We consider inhomogeneous networks structured by a connec-tivity parameter (strengths of the synaptic weights) with the effect of processing the input current with different intensities. We first study the properties of the network activity depending on the distribution of synaptic weights and in particular its discrimination capacity. Then, we consider simple learning rules and determine the synaptic weight distribution it generates. We outline the role of noise as a selection principle and the capacity to memorized a learned signal.
distrib_connec_HAL.pdf (449.4 Ko) Télécharger le fichier
hal-01541093 , version 1 (17-06-2017)
Benoît Perthame, Delphine Salort, Gilles Wainrib. Distributed synaptic weights in a LIF neural network and learning rules. Physica D: Nonlinear Phenomena, 2017, 353-354, pp.20-30. ⟨10.1016/j.physd.2017.05.005⟩. ⟨hal-01541093⟩
717 Consultations
305 Téléchargements
