Monte-Carlo Algorithms for Forward Feynman-Kac type representation for semilinear nonconservative Partial Differential Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monte Carlo Methods and Applications Année : 2018
The paper is devoted to the construction of a probabilistic particle algorithm. This is related to nonlin-ear forward Feynman-Kac type equation, which represents the solution of a nonconservative semilinear parabolic Partial Differential Equations (PDE). Illustrations of the efficiency of the algorithm are provided by numerical experiments.
Paper_Simulation20170911SubmittedMonteCarlo.pdf (285.36 Ko) Télécharger le fichier
hal-01586861 , version 1 (13-09-2017)
Anthony Le Cavil, Nadia Oudjane, Francesco Russo. Monte-Carlo Algorithms for Forward Feynman-Kac type representation for semilinear nonconservative Partial Differential Equations. Monte Carlo Methods and Applications, 2018, 24 (1), pp.55-70. ⟨10.1515/mcma-2018-0005⟩. ⟨hal-01586861⟩
191 Consultations
224 Téléchargements
