Peripheral state persistence for transiently-powered systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recently has emerged the concept of transiently-powered systems: tiny battery-less embedded systems which harvest energy from their environment. To retain information despite frequent and unpredictable power failures, a transiently-powered system can use non-volatile memory to store checkpoints of program state. However current checkpointing techniques only consider the state of computation (processor, memory) and disregard peripheral state completely. This paper presents a software framework that allows for the use of non-trivial peripherals such as analog-to-digital converters, serial interfaces or radio devices, in transiently-powered systems.
ioent-2017.pdf (324.79 Ko) Télécharger le fichier
hal-01609277 , version 1 (03-10-2017)
Gautier Berthou, Tristan Delizy, Kevin Marquet, Tanguy Risset, Guillaume Salagnac. Peripheral state persistence for transiently-powered systems. IoENT 2017 - 1st Workshop on Internet of Energy Neutral Things, Jun 2017, Geneva, Switzerland. ⟨10.1109/GIOTS.2017.8016243⟩. ⟨hal-01609277⟩
260 Consultations
229 Téléchargements
