Aural servo: sensor-based control from robot audition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Robotics Année : 2018
This paper proposes a control framework based on auditory perception. Generally, in robot audition, the motion control of a robot from the sense of hearing relies on sound source localization. We propose in this paper an alternative approach, aural servo, that is derived from the sensor-based control framework. In this approach, robot motions are directly connected to the aural perception: the variation of low-level auditory features dictates the motions applied to the robot through a feedback loop. It has the advantage of being robust to spurious measurements and modeling approximations for a low computational cost. This paper presents the theoretical concept of the aural servo framework. Besides a theoretical analysis, the aural servo framework is validated through several experiments on different robotic platforms and under real-world conditions.
2018_magassouba_tro.pdf (1.67 Mo) Télécharger le fichier
hal-01694366 , version 1 (27-01-2018)
Aly Magassouba, Nancy Bertin, François Chaumette. Aural servo: sensor-based control from robot audition. IEEE Transactions on Robotics, 2018, 34 (3), pp.572-585. ⟨10.1109/TRO.2018.2805310⟩. ⟨hal-01694366⟩
379 Consultations
318 Téléchargements
