Cost Optimization of Cloud-RAN Planning and Provisioning for 5G Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper, we propose a network planning and provisioning framework that optimizes deployment cost in C-RAN based 5G networks. Our framework is based on a Mixed Integer Quadratically Constrained Programming (MIQCP) model which optimizes " virtualized " 5G service chain deployment cost while performing adequate provisioning to address user demand and performance requirements. We use two realistic scenarios to showcase that our framework can be applied to different types of deployments and discuss the computational cost and scalability of our solution.
icc2018.pdf (530.02 Ko) Télécharger le fichier
hal-01707682 , version 1 (13-02-2018)
  • HAL Id : hal-01707682 , version 1
Osama Arouk, Thierry Turletti, Navid Nikaein, Katia Obraczka. Cost Optimization of Cloud-RAN Planning and Provisioning for 5G Networks. ICC 2018 - IEEE International Conference on Communications, May 2018, Kansa City, MO, United States. ⟨hal-01707682⟩
588 Consultations
386 Téléchargements
