Maximum likelihood drift estimation for a threshold diffusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scandinavian Journal of Statistics Année : 2020
We study the maximum likelihood estimator of the drift parameters of a stochastic differential equation, with both drift and diffusion coefficients constant on the positive and negative axis, yet discontinuous at zero. This threshold diffusion is called drifted Oscillating Brownian motion. For this continuously observed diffusion, the maximum likelihood estimator coincide with a quasi-likelihood estimator with constant diffusion term. We show that this estimator is the limit, as observations become dense in time, of the (quasi)-maximum likelihood estimator based on discrete observations. In long time, the asymptotic behaviors of the positive and negative occupation times rule the ones of the estimators. Differently from most known results in the literature, we do not restrict ourselves to the ergodic framework: indeed, depending on the signs of the drift, the process may be ergodic, transient or null recurrent. For each regime, we establish whether or not the estimators are consistent; if they are, we prove the convergence in long time of the properly rescaled difference of the estimators towards a normal or mixed normal distribution. These theoretical results are backed by numerical simulations.
estimation_drift_obm_r2.pdf (919.7 Ko) Télécharger le fichier
hal-01731566 , version 1 (14-03-2018)
hal-01731566 , version 2 (24-01-2019)
hal-01731566 , version 3 (20-08-2019)
Antoine Lejay, Paolo Pigato. Maximum likelihood drift estimation for a threshold diffusion. Scandinavian Journal of Statistics, 2020, 47 (3), pp.29. ⟨10.1111/sjos.12417⟩. ⟨hal-01731566v3⟩
378 Consultations
337 Téléchargements
